69 dart control arms
Old Feb 18, 2012 | 04:18 PM
willysman69's Avatar
I have a location on a 75 vilaint need to know if the front bolt pattern would be 5 on 4 1 /2 thanks
Old Feb 18, 2012 | 05:00 PM
75 should be disk brakes and large pattern. If you want to put the discs on your car, you'll need the upper control arms, the spindle and of course brake parts, caliper, etc
I'd get the proportioning valve (brass block down below the master) as well as the master and at least the NUTS off the old lines. That's because the master and prop. valve do not use "standard" nuts for 3/16 tube.
boozy
Jun 18, 2011 06:49 AM
daryld
May 29, 2011 06:44 AM
79woodnick
Jul 29, 2010 03:26 AM
just-suspension
Jun 26, 2009 01:38 PM
Jan 13, 2009 10:25 AM
