Driveshaft Problems after Engine Swap!!! Help???
Old Apr 27, 2012 | 08:17 PM
klayton9's Avatar
Exclamation Driveshaft Problems after Engine Swap!!! Help???
I swapped out my 225 slant 6 engine out of a 1974 plymouth duster and dropped in a .30 over 318. I bought a 904 transmission and had it rebuilt, and after i bolted the transmission up, my driveshaft seems to be about 2 inches too long. I crammed it up there, but there is no play and it just doesn't seem right. I am not quite sure what to do. Anybody have any ideas on what is wrong? Hopefully I can get some answers. Might just have to take it down to the machine shop and have it shortened and balanced? Thanks for your time guys.
Old Apr 27, 2012 | 08:42 PM
PM replied to.
Old Apr 27, 2012 | 09:22 PM
Are you sure it is a 904 and not a 727 ?? DO NOT try and drive it that way
Old Apr 28, 2012 | 06:24 AM
Archer's Avatar
klayton -
That's happens a lot with engine swaps; either too long or too short. You're going to have to take it to a shop that does drive shafts and have it cut to size (or have a new one made, they should use you're old U-joints).
Unless the shop will remove the drive shaft themselves, they will ask for very specific measurements.
Old Apr 28, 2012 | 03:00 PM
I hope this will help: http://board.moparts.org/ubbthreads/...riveshafts.pdf
Old Aug 20, 2012 | 06:07 PM
bdusted440's Avatar
Have it shortened.
xvodysseusvx
Jun 25, 2018 04:38 PM
Mopardik
Apr 19, 2012 10:57 AM
66 A100VAN
May 14, 2010 08:29 PM
71RR08
Aug 12, 2008 10:42 AM
ccflash22
Nov 12, 2007 04:22 PM
