Ignition switch issue
Old 05-05-2020, 04:20 PM
viasloth's Avatar
I have 67 Dart v8, that I just acquired from a friend, however I get no power to anything when I turn the key and the ignition switch is brand new. Looking for some suggestions and help as to determining what may be the issue. Thank you
Old 05-07-2020, 09:34 AM
Check the Voltage across the AMP Gauge.....
Old 05-25-2020, 09:04 PM
Katgerdy's Avatar
I don’t want to give you bad advice as I’m needing help also. I can tell you some things to check as I’ve had that happen many times to me. First was the fuseable link, the coil, ballast resistor, voltage regulator, and somebody has messed up wiring or the wiring may just be old and needs to be replaced like mine is. The last owner of my car ‘1974 Valiant’ put in a phone charging port and auxiliary for speakers and a big amplifier in the trunk. I’ve undone all of that but wiring shew.
rdrodgers
10-10-2020 09:35 AM
buttton
04-06-2013 08:42 AM
Arbiter343GS
10-31-2011 08:44 AM
JPETRO1051
02-14-2011 02:30 AM
dnoonkeste
10-05-2008 12:19 PM
Quick Reply: Ignition switch issue
