need help decoding this transmission PLEASE HELP
Old Aug 14, 2010 | 12:08 PM
73plymduster's Avatar
i just bought my first mopar so i'm new at this. so towards the back it says c 956S8U or its two s's or two eights i can't tell. and the other side it says C - 95658 - P Can anybody help???
Old Aug 14, 2010 | 01:11 PM
blue 68 gts's Avatar
Not sure why you need to decode the numbers on the trans. Some years came with the VIN stamped in the bellhousing.
Are you trying to figure out what the transmission is out of (if swapped into your car at a later point) or what type of transmission it is?
What motor do you have?
Old Aug 14, 2010 | 06:44 PM
mr340's Avatar
Those look like casting numbers, the auto should have the VIN stamped on the pan rail and the stick should have it on a machined pad on the right side.
Old Aug 14, 2010 | 10:30 PM
i know it's a four speed transmission. but i'm pending a buy on a 383 engine and was wondering if this transmission would work for the engine? the guy says it's a mid to late 60's mopar transmission.
Old Aug 14, 2010 | 11:14 PM
1966sportfury's Avatar
A.K.A Bob Dodge
those numbers dont come up with nothing for me, the 1st number should be a 2 or 3, according to my source, if its a 4 spd manual it will fit BB or SB what really matters is the bell housing
Old Aug 15, 2010 | 04:52 AM
mr340's Avatar
Look on the right side of the unit for a pad similar to this with an additional set of #'s on it.
Attached Thumbnails need help decoding this transmission PLEASE HELP-aod004.jpg
Old Aug 15, 2010 | 10:21 AM
alright thanks. i'll see if he can get the other numbers
hdokes
Mar 10, 2015 06:03 AM
thepickupplace
Cuda Specific Discussion
Jun 29, 2013 09:18 AM
71mopar
Oct 18, 2009 12:09 AM
plymouth
Aug 5, 2009 01:49 PM
Zach8200
May 21, 2009 12:24 PM
