new to the mopar world
Old Aug 12, 2009 | 06:10 PM
mr340's Avatar
You got a slant with a 8.75 rear??? which part's not original? I'll guess it's the rear...
Old Aug 12, 2009 | 08:21 PM
mr340's Avatar
That motor is about as reliable as a sunrise! you can pretty much always count on it to be there for you. Pretty near indestructable. As for the '74 Duster, the only experience I have with it is one I owned in the early '80's, it too was a 225, but I had a "3 on the tree", it was a blast to drive till I needed the motor for a Demon, then the Duster became a parts car...
Old Aug 13, 2009 | 06:03 AM
Welcome.
Are you sure the rear is an 8 3/4"? I don't know why someone would swap one in unless they had plans for a built small/big block motor.
Old Aug 13, 2009 | 04:38 PM
the rear end is probably not original, but it is great that you have it
Old Feb 6, 2010 | 10:16 PM
mopardrt's Avatar
check the bolts on the back of the case member if its a rear load its a 7 1/4 or 8 1/4 if its front load it is most likly a 8 3/4
SillyxMongoose
May 16, 2013 04:24 PM
Branden Stevanus
Sep 27, 2012 12:44 PM
jsacks1981
May 13, 2012 04:28 AM
Dartster
May 20, 2010 08:23 PM
cyah
May 9, 2010 07:30 PM
