No power
Old Nov 16, 2020 | 06:10 PM
Thomas J. Cox's Avatar
Angry No power
I have a 1972 plymouth valiant 318. Last night I was driving and when I put my lights on my voltmeter went all the way over to the high charge and then the car died. Would not start nothing. tested battery today and it was good. looks like there is some black soot on the alternator. Would a burned out alternator cause the car not to start at all?
Old Nov 16, 2020 | 07:26 PM
Archer's Avatar
Thomas -
A car doesn't need an alternator to "start", but if the alternator blew or rather burnt and took a few wires with it, then maybe.
I'd take a good good at all the wires and replace any harnesses that look questionable.
Old Nov 16, 2020 | 07:43 PM
Hi, thanks. I don't see any burned wires.
Old Nov 17, 2020 | 01:10 AM
fivepoint's Avatar
I would take a hard look at your harness. Sounds like when you turned the lights on, something put a hard draw on the system. It could be behind the dash or at the bulkhead connector.
Old Nov 17, 2020 | 01:19 PM
John Van's Avatar
Like fivepoint said, On my '73 I had to jump over the bulkhead connection that burned and replaced the ammeter for a voltmeter. Good luck!
Old Nov 24, 2020 | 09:41 AM
Also may be good idea to inspect voltage regulator and ballast resistor, and trace all grounds to the lighting system.
Old Nov 26, 2020 | 09:55 AM
I have a 1972 plymouth valiant 318. Last night I was driving and when I put my lights on my voltmeter went all the way over to the high charge and then the car died. Would not start nothing. tested battery today and it was good. looks like there is some black soot on the alternator. Would a burned out alternator cause the car not to start at all... Found a fusable link that was burned. replaced it and still no power. Battery is fully charged.. Frustrated. Doies not click when I try to start it.
Andere_Wisp
Sep 16, 2020 10:05 AM
Eric Goody
Apr 26, 2017 10:14 AM
64Imperial
Oct 3, 2016 09:56 PM
panda!
Jun 4, 2009 11:54 AM
SixtySevenDodge
Apr 9, 2009 08:15 PM
