Power to Manual steering
Old 05-22-2010, 10:41 PM
thedusterridesagain's Avatar
so i wanna change over to manual steerirng. a buddy of mine has a manual box from a 1970 challenger and from what i can find it will fit in my 74 duster. he also has the coupling from the steering shaft to the box. anything else i will need for the swap like pitman arm or any other kind of coupling thingy? thanks ahead of time.
Old 05-27-2010, 02:22 PM
blue 68 gts's Avatar
You need the manual box, and either an adapter on the steering column, or a rod out of a manual steering car that you'll put into your power steering column.
The adapters are about $150
Old 05-28-2010, 08:49 AM
thanks blue. any idea where i could get the adapter? or would the one from his car work on mine?
Old 05-28-2010, 10:43 AM
I'm not sure about that. The splines may be different.. Make sure you count the splines on the e-body box and your a-body box. One off, won't work.
I'll try to find a link for the one i got
Old 05-28-2010, 09:33 PM
mopardrt's Avatar
why would u wana do that? i love power
Old 05-30-2010, 07:58 PM
thanks blue i appreciate it. and drt i really like the feel of manual. plus my power leaks like a bp oil rig and if driven manual cars before. i feels more responsive and since i don't drive my car everyday its not a big deal.
Old 05-31-2010, 11:22 AM
Crazy4Carz.Com's Avatar
Firm feel has the adapter.
Old 09-20-2012, 02:12 PM
wayback64's Avatar
conversion
ok im also wanting to change over to manual. I have a 1964 belvedere with power steering and I want to change over to manual. where's the best place to get a box and the adapter.
Old 09-20-2012, 03:22 PM
It sounds like you have all the needed parts The coupling (adapter) the box should fit fine. Splines are the same after 68 ??? . YOU will not like the change The stock manual box takes forever to turn. It is NLA but they used to offer a quick ratio manual box. I would check with Firm feel to see what is available.
For wayback64 the steering box would have the smaller spline pitman arm so that would need to be changed too!
Old 09-20-2012, 05:25 PM
Some of the manual boxes (later) have a larger spline on the pitman shaft. Make sure you get the correct one.
The column shaft is a different length so you'll need an aftermarket coupler for that purpose, or change the column shaft.
Old 09-20-2012, 07:57 PM
Joeychgo's Avatar
Here are a few articles:
6. No promotions of other related sites. There is no problem with occasionally using the name of other sites or even posting a link to a pertinent thread from another site, but repeatedly referring to other related sites is considered "SPAM" and is not allowed. Please have the decency of NOT putting links to them in your signature, profile or have a post, PM or Chat telling our members to come over to another related site. Such activity is ground for removal from signature, and repeated offenses are grounds for being banned.
HorizonChaser
05-17-2015 02:41 PM
HonkyCat
11-03-2012 10:09 AM
1966DartConvertible
11-07-2010 10:24 AM
OHD
04-07-2010 04:40 PM
1 Bad Mirada
05-16-2009 05:24 AM
Quick Reply: Power to Manual steering
