Small Block Recipe
Old May 13, 2010 | 11:26 PM
chlngr1970's Avatar
Small Block Recipe
I need a good small block recipe for my '68 Dart. I have a 318, 340, and 360. I'm looking for about 3-350 HP/TQ with a VERY streetable combination. Automatic and manual brakes, probably 3.23 or 3.55 sure grip will back the motor up. I'd kinda like to save the 340 for a really special ride, like a Demon, or a 'cuda Notch. along the same line, I have the 8.75 coming out of my Duster in favor of the Dana 60 I got a few weeks ago. I also have the 8.15 that came from the Sport. Again, I am wanting to save the 8.75 for that special project, but if convinced I need it, I'll put it in.
Here is what I have in mind.
  • 318 block
  • 318 Crank
  • 9:1 CR
  • Mild head prep
  • Edelbrock Performer Intake
  • Edelbrock Performer Cam
  • Carter 625 AFB
  • Headers, 2.25 exhaust W/H Pipe
What do y'all think? Descent street combo? Not looking for a boulevard bruiser, but a good street car. I will have my Duster for that
j
Old May 14, 2010 | 12:06 AM
1966sportfury's Avatar
A.K.A Bob Dodge
dont sound bad at all..id probly bump the CR up a bit. but with right bump stick and head work should be able to get an easy 300 hp
Old May 14, 2010 | 03:27 AM
Why not do that to the 360 instead? You'll get closer to the numbers that you want. I would bump up the compression to 9.5:1 as well. What did you have in mind for "mild head work"?
Also, since you are going with an auto, I would skip the Performer cam and intake a get the Performer RPM cam and intake as that will start to create th epower you want as the automatic trans is getting the car moving. Also, install a shift kit in the trans with a stall convertor around 2000 RPM. I think that you will be much happier this way. You'll still have a nice ride and plenty of power for the street and still be able to take it to the track when you get that need.
I wouldn't touch the 340 or 8 3/4 for this though. A well built 8.25 should be fine. If you can get your hands onto a 9.25, that would be better.
Old May 14, 2010 | 03:28 AM
Oh yeah...... It's nice to see you back!
Old May 16, 2010 | 09:33 PM
jeremy e's Avatar
Junior Member
look at this im looking at about the same thing for my 73 duster
HOT STREET PERFORMANCE (2200 rpm to 5200 rpm, max. HP @ 6200 rpm)
Strong upper rpm performance for street machines. Not for towing.
Multi-angle valve grind is recommended.
ENGINE CAM RANGE* CARB CFM RANGE HORSEPOWER
273 21800 to 22600 557 to 674 cfm Max. 300 HP
318 2Bbl & FI 22100 to 22900 649 to 785 cfm Max. 350 HP
318 4Bbl 22000 to 22800 649 to 785 cfm Max. 350 HP
340 68-71 22000 to 22800 694 to 840 cfm Max. 374 HP
340 72-73 22100 to 22900 694 to 840 cfm Max. 374 HP
360 22300 to 23100 735 to 889 cfm Max. 396 HP
360 LTrk 76-80 22500 to 23300 735 to 889 cfm Max. 396 HP
360 w/2.02 22100 to 22900 735 to 889 cfm Max. 396 HP
*The cam range refers to the 2nd half of
the Accelerated Motion part number.
Compression: Gasoline 9.5:1 to 11.0:1, Propane 11.0:1 to 12.5:1
Exhaust: Dual exhaust with headers
Gear Ratio: 3.5:1 to 4.5:1
Idle: 1000 rpm or less, has a lope
Ignition: Recurved or perf. distributor, electronic ignition
Old May 16, 2010 | 09:42 PM
jeremy e's Avatar
Junior Member
soory mis some of it cam
All 235/244 .487/.508 307/307 112 20871-23649
All 243/243 .508/.508 298/298 108 20871-24550 Wh
All 248/248 .509/.509 292/292 108 Mopar P4120233
Old May 16, 2010 | 10:39 PM
A.K.A Bob Dodge
what book did you get that from?
Old May 17, 2010 | 09:11 AM
jeremy e's Avatar
Junior Member
http://www.amotion.com/mla.html here is were i fonnd the recipe
Old May 17, 2010 | 09:31 AM
chlngr1970's Avatar
I was thinking 318 just for the fact I can say I beat the competition with "just a a318" The 360 is also on the table as I don't want to be too limiting on my options. I think it would cost about as much either way..so...
318:
  • 9.5:1 CR
  • Performer RPM Intake, carb, and cam
  • Mild head work ( probably around $500 worth per head I thnk )
  • Same as above
I may end up using the 360, just don't know yet.
Anybody recommend a good converter, and trans kit?
And thanks for the WB =) It's good to be working on the cars again. Shame I had to go and brake my truck tho Still bummed about that. My GF want's me to give the truck to her daughter and make her fix it. She says she ( the daughter ) wants it...
j
Old May 17, 2010 | 09:54 AM
I like what B&M puts out for shift kits and stall convertors but TCI is just as good if not better. I would think around 2200-2500 RPM stall rating would be good for the motor that you want to build.
The 318 and 360 cranks have the same stroke? If not, *hint*hint*
Old May 18, 2010 | 06:18 PM
chlngr1970's Avatar
The 360 has larger journals IIRC. It would be like putting a 440 crank in a 400, but I see your point. Also, the 360 is externally balanced while the 318/340 are internally balanced. Anyway...I'm not wanting to go too radical with it, as I might end up selling it to help pay for getting the Duster finished
j
Old May 19, 2010 | 02:59 AM
Just a thought.
Do what you need to do and get that duster done! It's good to see you back on here bro.
pipdog69
Mar 13, 2012 11:01 PM
74bbroadrunner
Mar 13, 2012 08:19 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
