Starting problems
Old Apr 13, 2009 | 08:30 AM
Polaradude's Avatar
Take off the fuel line and hold it in a can and get someone to crank er over a few times, getting fuel or not. Filter plugged, float stuck closed in carb, fuel pump ? Plugged jets etc etc.
Old Apr 13, 2009 | 09:50 AM
maybe your choke is out of adjustment, so it wont open enough to start the car
Old Apr 13, 2009 | 11:12 AM
Crazy4Carz.Com's Avatar
Hold the gas pedal down to the floor, DO NOT PUMP IT just put it there and hold it there. meanwhile, put a screwdriver in the carb to hold the choke plate open (yes it is supposed to be closed) and crank, and crank, and crank. all the time holding the pedal to the floor. Dont lift and start over just hold it there and crank.
There, it started right?
Old Apr 13, 2009 | 12:56 PM
Polaradude's Avatar
C4C has covered part 2 of the tech exactly.
Old Apr 13, 2009 | 01:01 PM
72RDRNR's Avatar
Just remember to remove the screwdriver before you close the hood
Old Apr 13, 2009 | 11:01 PM
theomahamoparguy's Avatar
hey those old choke pull offs tend to stick .I'd disconnect the choke linkage for now and see if it will start. [BTW the choke pull-off is located in the choke housing itself on that style of AFB] Also, the kickdown linkage does not look right, usually the pin that slides is towards the back of the slot when the engines not running.
xvodysseusvx
Jun 25, 2018 04:38 PM
mr_Sancho1324
Feb 3, 2011 09:05 PM
MMMichael
Nov 29, 2010 07:10 AM
prive81
Aug 3, 2010 06:50 AM
alsparl
Jul 7, 2009 03:39 AM
