stock rear end
Old Apr 16, 2011 | 02:13 PM
mark millhouse's Avatar
stock rear end
i have a 71 dart with a limited slip diff in it i would like an 8 3/4 but cant afford one what rearend does this car have and where can i find gears for it btw its a dirt track car
Old Apr 17, 2011 | 07:22 PM
if you post a pic of the rear, we should be able to identify it for you
Old Apr 18, 2011 | 09:31 AM
In the chart below, your possibilities are one of the top two
(You evidently don't have an 8 3/4, the only axle with a third member, and Mopar did not use the bottom two in your car)
Old Apr 19, 2011 | 02:33 AM
If you have a LS then it's probably going to be the 8.25 rear axle. Most places will have gears for it. While you have it apart, inspect the clutches in the LS and replace them if they look worn. No point in going in there twice.
oldiebutgoodie
Oct 12, 2012 04:03 PM
MReeves
Stock Eliminator
Dec 12, 2011 10:26 AM
Figment
Jul 4, 2011 11:42 PM
thekinzuakid247
Apr 3, 2007 07:37 AM
thekinzuakid247
Mar 25, 2007 01:56 PM
