Turn signal help
Old Oct 24, 2011 | 05:02 PM
Bcrusep86's Avatar
Turn signal help
Just got my first Scamp..1976.. and the turn signals don't work..fuses are fine..where do i go from here? the fuse box is labeled with just numbers..does anyone have a diagram for the signals so i know where to look? thanks
Old Oct 24, 2011 | 10:18 PM
mikerp76's Avatar
it may be your turn signal flasher. or the turn switch. not sure where the flasher i lated on your car but mine is near the glove box.
Old Oct 25, 2011 | 05:36 AM
Bcrusep86's Avatar
Is the turn signal flasher the same as the hazard flasher? because i got a new one and the hazards work fine
Old Oct 25, 2011 | 09:32 AM
No, separate flashers. Here's a wiring diagram from over at "My Mopar"
http://www.mymopar.com/downloads/1976/76ValiantA.jpg
http://www.mymopar.com/downloads/1976/76ValiantB.jpg
I don't know where the flashers are. Some late model stuff, the 4 way is on the fuse box. Signal flashers are up under the dash, remove the ashtray and look// feel for it clipped up there up under the dash rim by the ashtray, if not, over around the glove box.
If changing the flasher does not help, make sure you have power to the flasher. If you do, refer to the diagram, and probe around the connector under the steering column which goes up to the switch. A good place to probe and access the rear lights is the connector in the left kick panel.
Old Oct 25, 2011 | 09:58 AM
Bcrusep86's Avatar
ok thanks a lot..ill look at it later and let you know what i got..figure i start with the flasher before i pull the steering wheel off
Old Oct 27, 2011 | 10:15 AM
Bcrusep86's Avatar
Still could not find the flasher but i found the wire that was not hooked up to the fuse box..problem fixed..Thanks for the help
Old Oct 27, 2011 | 12:37 PM
motorcitymopar586's Avatar
one way to see if your turn signal cam broke off inside the wheel is try the cancellation. flip the turn signal so it would be flasshing left. then turn the wheel left a full turn and back a full turn. if it doesnt flip to off then you got problems in the column
157forj
May 1, 2013 06:21 PM
nesparky
Dec 12, 2011 07:05 PM
72RDRNR
Jul 5, 2010 01:40 PM
Steven Bowers
May 9, 2010 01:10 PM
dorseyh
Aug 12, 2009 10:52 AM
