Vacuum leak?
Old May 11, 2017 | 08:45 AM
Joey Guzman's Avatar
Question Vacuum leak?
I have had a heck of a time trying to track down a possible vacuum leak .
I have a 451 with Pro systems Carb and nitrous plate,all gaskets have been changed from the intake up to through the carb. The problem i am have is when i take for a drive once i come to a stop it will start to lean to 18-19 AF
It has all new fuel system and filters. I do hear a slight whistle but only when i drive it! I cant get it to do in park or even in gear slightly giving gas.
Old May 11, 2017 | 11:57 AM
Sounds like its lean all the time?
But just a question. What did you use to seal the intake to the cylinder heads?
Old May 11, 2017 | 12:39 PM
Permatex Ultra Copper Maximum Temperature RTV Silicone
I have a innovation air fuel gauge,At idle it sits at 12-13 airfuel
I do not hear a leaking sound at idle or even in gear. Im wondering if the whistle is coming from my carb needing more
Old May 11, 2017 | 01:40 PM
Do you have a different carb to try?
Old May 11, 2017 | 01:44 PM
If its a Holley knock off and has a power valve it might not be opening.
Old May 11, 2017 | 01:58 PM
I have a new Holley Dominator 950, I am going to pull my nitrous plate and see if that may be the issue.
Old May 11, 2017 | 03:24 PM
All 4 Corner Jets are the same size?
and you have all 4 idle air screws turned out the same amounts?
Good Idea on removing the plate till you sort it out...
Old May 11, 2017 | 04:04 PM
All corners are the same and everything was adjusted evenly.
Im going to slap a smoking gun tonight to see if i can see anything before i pull the plate.
Old May 12, 2017 | 10:51 AM
Sounds good...
keep us posted..
Old May 16, 2017 | 08:51 AM
UPDATE!
Well i put my smoking gun with air compressor. The smoke came out of both side of my primary throttle shafts! I ordered a o ring set to plug them.
Old May 16, 2017 | 02:30 PM
That's kind of to be expected... A little is ok...But not lot a boat load?
Can you pull the carb and install a block off plate and retest it?
Car has Power Brake? Booster could be leaking? or maybe the vacuum actuators inside the car?
josehf34
36
Dec 16, 2014 06:05 AM
Robert Weaver
Nov 21, 2014 08:11 PM
66coronetgirlie
Aug 9, 2010 10:41 PM
340CUDA
Mar 16, 2009 05:27 PM
Commando
Sep 23, 2008 07:35 AM
