flat black
Old May 26, 2013 | 07:35 AM
msbhvin duster's Avatar
flat black
Does anybody have ideas or tricks on how to clean my flat black hood on my duster?? Is there anything to use on it so I can dust it and not scratch it?? Thanks!!
Old May 26, 2013 | 10:14 AM
inri's Avatar
Msbhvin,
I have the same issue with my hood. The dust normally collects while parked in the garage. I even have a cover for the car, but the cover appears to have a lot of tiny ***** that come off and fall onto the car and hood. They are easily removed from the car with a cloth, but the hood not so much.
I too am curious to see what might help resolve this.
Old May 26, 2013 | 10:40 AM
Gorts 5th's Avatar
Smile
if this is the automotive flat paint it should wipe clean.
we used a additive that de-glossed the paint the more you added the flatter it became
never touch it with waxes that turn to a white powder this will leave a white stain. hell i don't even use them i use pure carnuba wax
if the flat is from a spray can well there is your problem.
Old May 26, 2013 | 11:35 AM
It was sprayed with the correct flat black automotive paint designed for the car sprayed by the best shop in my area!!
Old May 26, 2013 | 01:50 PM
pro-tech's Avatar
I use a California duster, Also use mothers spray wax to dampen a microfiber cloth and wipe it down. Always seems to work and not scratch the finish for me and looks great. How much dust are you talking??? What Im talking about is light dust any more than that I wash the car. I always thought it was called matte black which is more semigloss than flat. Flat black is like primer very porrous/rough and I could see where that could cause problems. From the factory I believe they where decals and were alot easier to care for. I might be wrong but I see decals listed for the Duster hoods.
Old May 26, 2013 | 01:54 PM
Gorts 5th's Avatar
Smile
what does the shop recommend to use?
pro tech has a good suggestion.
Old May 27, 2013 | 07:10 AM
I believe u are correct on the matte black. I will try the wax on my cali duster. I'm talking just a slight dust like just from driving down the road!!
Old May 29, 2013 | 02:20 AM
Any flat color is going to be porous and will hold onto dirt, dust, water, etc.. Ask the shop what they actually sprayed. Was it flat, matte or satin? Did they spray a satin/matte clear coat on it as well? I painted my old Honda motorcycle satin black (looks just like flat but without the pores) and then sprayed a satin clear coat on it. After letting it cure for 21 days, I was able to wax it and never had an issue with water spots or dust/dirt sticking to it.
Do you use a shammy after washing it?
Mother's make some great products too. That is all that I have used on all my vehicles for the last 8 years and won't use another else.
Old May 29, 2013 | 10:05 AM
i'd probably go the duster route, too.
Old May 30, 2013 | 10:36 AM
Yes I shammy it after washing and it looks great for awhile!!!
Old May 31, 2013 | 02:19 PM
You could always just not let it get wet.
rb70383
Jun 11, 2014 06:15 AM
mike
Nov 17, 2010 07:02 PM
Nomadci
Sep 5, 2010 01:16 PM
deadkelly
Mar 28, 2010 06:08 AM
peddeler
Jan 30, 2008 06:35 PM
