PCM NOISE.
Old Jun 3, 2013 | 03:02 PM
romayel's Avatar
PCM NOISE.
GREETINGS... I HAVE A 1996 Chrysler Sebring convertible 2.5 with a no spark issue. I noticed that the PCM is making a high pitch ringing sound . it's rings continuously while the key is in the run position . i was wondering if this was normal or if it could mean that i have a bad PCM reason for the no spark. attached a multimeter to the two prong connector at the distributor and grounded other multimeter prong. multimeter shows about 1 or 2 volts. not showing any trouble codes. the ringing PCM sounds like a high pitch dog whistle only not as loud. should i replace the PCM or is this normal. is there a way to test my PCM. please Help im about to loose my job cause i don't have transportation. please hurry some body any body... smh ...thanks in advance
Darren Muncy
Oct 5, 2013 03:33 AM
Darren Muncy
Oct 4, 2013 12:12 PM
Beerstop
Nov 5, 2011 11:17 AM
doug2060
Aug 28, 2010 04:33 PM
MichaelSB
Aug 16, 2010 12:08 PM
