Dana 60 install questions.
Old Aug 18, 2016 | 10:22 AM
Bill Kay's Avatar
Hi.. I am new here but not new to owning a Dodge PW. I have had my 1977 W100 short box for years now and the front hub went bad, I was having issues finding a 1/2 ton hub however I ran up on a set of mid 70's 3/4 ton axles from a Dodge. My questions are. Will the stock rear drive line still fit with a simple u-joint replacement. Second are the u-bolt mounting plates the same as the ones on my half ton axle? I am sure these aren't new questions but, the internet is full of misleading info so, it's better to ask those who know. Thank you.
Old Aug 18, 2016 | 11:26 AM
I just might have a hub, what side do you need?
Old Aug 18, 2016 | 01:12 PM
I think the Perch spacing is different...
Old Aug 19, 2016 | 08:58 PM
Bill Kay's Avatar
That would great and get my old girl up and going brother. The left front went bad but aren't they the same? All I need is the bearing hub and the axle nut, rotor and other stuff not needed. Please let me know what you want for it shipped, zip code 85207 Thank you.
Old Aug 20, 2016 | 05:50 AM
I will have to look , I think I know location of part but it has been 25+ years since I put it there.
Did the axle nut come lose?
If I have the parts there yours for the ride.
Old Aug 21, 2016 | 12:57 PM
Bill Kay's Avatar
The nut cracked on me however, I found that a 1990's- early 2000's 2500,3500 front axle nut is the same. Mopar wants 100 bucks for it and they stock it. It looks like the hub will hook me up brother. Thank you again Iowan. Bill harleybill@q.com.
Old Aug 25, 2016 | 03:10 PM
Bill Kay's Avatar
I'm not sure what happened to last weeks reply but, it's not here. My nut cracked when I took it apart. I found the nut at the dealer. It also fits 2500 and 3500 trucks. I just need a hub Iowan. Thank you.
Old Aug 25, 2016 | 03:23 PM
Sorry got a lot going on, I will get out there first thing in the am..
Old Aug 26, 2016 | 08:44 AM
I sold my truck about five years ago and thought I had a spare set of axles hubs and bearing retainers, but they must have gone with the truck because all I found was one bearing retainer. I did find a set of 906 heads I forgot that I had along with other things, sorry I can't help.
You know you have to much stuff when it takes you an hour to get five feet in the door.
Sdulent
Jun 20, 2010 06:01 PM
phatdak18
Jan 3, 2009 07:57 AM
edwin 440
Nov 18, 2008 05:19 PM
mopar nate
Nov 11, 2008 01:14 AM
499coronet
Feb 18, 2007 12:48 PM
