67 Dodge Coronet
Old Mar 24, 2015 | 04:01 PM
Bigmark's Avatar
67 Dodge Coronet
I have a 1967 Dodge Coronet 500 with a 383 and edelbrock performer 4 barrel carb. The problem is it won't start unless I prime it with some gas or starting fluid. After I get it going it will start without priming the rest of the day. The next day gotta prime the carb again. The carb is not a junk carb, it has a new fuel pump. It seems that the carb bowl is draining but the fuel inlet line is higher than the bowl. Any ideas?
Old Mar 24, 2015 | 06:23 PM
I WOULD START BY CHECKING THE HOSES AT THE TANK
dam cap key
Old Mar 24, 2015 | 06:49 PM
Welcome to the Site...
Sounds like the Bowl is dripping after it is shut off ??????
LOL...Lynn....
Old Mar 25, 2015 | 07:07 AM
Bigmark's Avatar
Old Mar 25, 2015 | 07:08 AM
Bigmark's Avatar
gas tank and fuel hoses are all new.
Bigmark's Avatar
LOL...Lynn....
Old Mar 25, 2015 | 07:11 AM
Bigmark's Avatar
Is there a place for the bowl to drain on the bottom of the carb bowl? If I remember right, the fuel line inlet is above the carb bowl so it couldn't be draining back down the fuel line. Its an edelbrock performer carb, a Carter AFB copy basically.
Old Mar 25, 2015 | 07:12 AM
Bigmark's Avatar
dam cap key
Bigmark's Avatar
Old Mar 25, 2015 | 04:05 PM
moe7404's Avatar
toss the mech pump and get an electric pump. make a over ride switch to fill the carb before starting. and a low oil cut off switch. edit: a good pump can even pull fuel from the tank to the engine compartment. an elect pump will save the starter and batt.
SteveRT
Oct 15, 2014 04:24 PM
johns5869
Sep 28, 2008 05:53 PM
1dart2nv
May 27, 2008 03:50 AM
GLASSMAN
Jan 8, 2008 01:34 PM
moparsforlife
Nov 27, 2007 01:14 PM
