Cam suggestions and hp estimates
Old May 10, 2017 | 01:30 PM
Davejmm's Avatar
400 block
400 rod
4.380 bore
3.9" stroke
440 source heads (80cc)
Aiming for about 11.5 CR (unless you guys think that's to high for 93 octain)
Cam ?
Aproxx 25002500lbs vehicle
Hoping to put manual transmission. But if auto will be about 3500 stall
3:55, 3:91 rear.
Old May 10, 2017 | 03:17 PM
I would say 10.5 CR max, but would go lower myself.
What pistons are you putting in it?
Old May 10, 2017 | 03:22 PM
Make it 12.5 and run e-85.
Old May 10, 2017 | 03:24 PM
There's a good idear.
Old May 10, 2017 | 07:35 PM
Its a cool fuel!
Old May 10, 2017 | 08:10 PM
Davejmm's Avatar
Have a set of pistons for a 451stroker. But had a 470 crank basically handed to me. Was looking to cut .05-.06" off the top of pistons to make up for added stroke.
Old May 11, 2017 | 06:33 AM
Ya , I wouldn't go there.
Get a good set of pistons and H beam rods. But before you o have the crank magnafluxed and check it for undersize etc..
Old May 11, 2017 | 06:55 AM
The thing about the 400 block is you need to have it sonic checked because the walls are THIN and with core shift are not centerd. You might check three or six blocks before you find one you can bore to 4.375 safely. I would go with the smallest overbore need to reduce the risk of blowing the walls out of the cylinders.
THEhomelessONE
Jan 22, 2017 02:43 PM
aeonmcallister
Aug 1, 2014 02:32 PM
65CoronetTX
Jul 21, 2014 07:52 AM
dusterboy89
May 26, 2011 07:38 AM
Slice
Feb 5, 2010 04:22 AM
