1972 D100 wiring diagrams
Old Jan 2, 2020 | 02:38 PM
Nathanael Hull's Avatar
Hi guys I am looking for some help regarding wiring diagrams. I have a service manual for my d100 and have been using it quite a bit for some wiring work. It has helped a lot however know I need to know where some of these wires go without having to cut the harness up and search. On the diagram there is a code (say B16) followed by a number and color code (which I have learned is the gauge of wire and the color). What I need to know is what the first code represents and if it tells me what the wire goes to. Any help would be much appreciated!
Old Jan 3, 2020 | 05:12 PM
You are correct. That, That you have circled is the location. However I do not have a chart to share. Sorry.
Old Jan 4, 2020 | 07:39 AM
Thank you for replying! Yeah that is my problem i cant find a chart explaing what those are. A few years ago i had one wire go up in flames and it caught 2 others, i knew where 1 went so it was rmeasy to replace. I have cut open the wire loom and found good wire on the other 2 but i dont know where they are supposed to go as when they burned they virtually disintegrated. Working on replacing bulk head connectors and re working wires and that is my only hang up as of now!
Old Jan 5, 2020 | 01:34 PM
I'm Guessing you will just have to use the Bulkhead placement of the wire and trace it from the wiring diagram to figure out where the wires go. Or Just leave those slot empty untill you can figure out what is not work after getting it all back together>
Old Jan 5, 2020 | 02:25 PM
yes! Thats just made difficult because the wire burned then corroded and disintegrated i think it has something to do with brake lights but not for sure. Im replacing the bulkhead connector all together!
Old Jan 22, 2020 | 12:28 PM
RCCadman's Avatar
See if this answers any of your questions. It helped me.
Old Jan 22, 2020 | 06:02 PM
yeah ive tried that but the wiring diagrams i have dont show the whole truck. For instance it shows coming out of the firewall and just ends with the code. Know where i can get a full truck diagram? I have a feeling it has something to do with turn signal or emergency brake light
Old Jan 23, 2020 | 05:24 AM
RCCadman's Avatar
I have a Factory Service Manual for my ramcharger that has the full set of wiring diagrams. You may be able to find one cheaper on EBAY, but this is what all of us need for our rigs.
Amazon Amazon
Old Jan 23, 2020 | 08:32 PM
https://www.amazon.com/PICKUP-TRUCKS...SIN=B00I6E8SRY
thanks for the link! Yeah i have a CD-rom version i bought on rock auto a few years ago it just doesnt have everything. Guess i need to get a different one bc its missing other things as well. I appreciate yours and everyone help! Another question for yall though regarding rear ends. Im trying to figure out if mine is a 8 3/4 ring gear or a 8 3/8. Today i was looking at it and its a 10 bolt and the housing has a 9 on it (not sure the significance) any ideas? Its a 318 RWD truck
Old Jan 24, 2020 | 05:27 AM
RCCadman's Avatar
I would start here but it doesn't mean someone hasn't swapped out the diffs in it.
https://www.randysworldwide.com/diff...tion-chrysler/
https://www.differentials.com/techni...dentification/
Old Jan 24, 2020 | 10:33 AM
http://www.autobooksbishko.com/Items...nual/3492.html
Old Jan 31, 2020 | 04:10 AM
I found the wires!!
After alot of tracing and crawling around the truck i have figured out the wires!! So if anyone ever needs to know here it is. B16 is an emergency brake light wire. It run from the switch on the panel up to a round plug on the back of the instrument panel where it goes to a light indicator. It then splits off and runs down to the bulkhead located on the firewall, there the 2 blu/wht (code B16)wires come together and make one out the engine bay side and run to power.
stokedandstupid
Mar 27, 2017 01:53 PM
Keith Roberts
Jan 24, 2017 06:06 PM
jtball
Aug 7, 2011 04:44 AM
old tired rebel
Nov 11, 2009 02:56 PM
Commando
Dec 28, 2008 04:20 PM
