1978 Power Wagon Smog Equipment
Old Oct 27, 2013 | 08:08 PM
ctdfan's Avatar
Im looking into buying a 1978 Dodge W150 Power Wagon 360 Auto. All the Smog Equipment was taken off. My question is what smog equipment came on the truck stock? I don't wanna buy it if I'm gonna have to put tons of money into it.
Thanks
Old Oct 27, 2013 | 08:59 PM
moe7404's Avatar
it depends on the smog tests in your state. my self if i was a smog test state i would NOT buy the truck. i herd of trick. you spike the gas with a bunch of methanol. it will pass the test . but run very poorly.
Old Oct 27, 2013 | 10:08 PM
If there is any inspection IT WILL need to have a cat converter that can get expensive. EGR valve hooked up and working.. vapor canister.. OEM air cleaner lots of stuff
Old Oct 27, 2013 | 10:13 PM
Yup. Very first "job" is to contact your state and check requirements. Some states drop off older vehicles as time goes on, some do not. Some like Arizona, are completely stupid. Hell we had a thread "over there" by some guys AZ has requirements for SIXTY SEVEN cars which didn't even ever COME with smog gear, 'cept PCV
Old Oct 29, 2013 | 10:26 AM
yea, it's going to depend. i've a '78 ramcharger and it isn't running cats. it has a few vac lines coming from a container by the passenger wheel well, and i'm in the process of getting it ready for smog, too.
have you checked out ramchargercentral.com? the guys over there know a ton more than i do and a lot of guys with trucks sign up and create build threads.
Old Oct 29, 2013 | 03:54 PM
moe7404's Avatar
i remember in 1975 chrysler had a 318 in the charger WITH a cat, AND one without a cat. the other car makers whined and cryed about having to use cats. and the government MADE chrysler put cats on all cars. booo hooo iam no good at building good equipment.
Old Nov 6, 2013 | 04:22 PM
ctdfan's Avatar
Yeah I live in California so I have a feeling the truck will cost a ton to get it to smog. I offered the kid $250 and he said he would take it. I was initially thinking about driving it out to Missouri and Registering it there because there is no smog and I own land there but then id have to drive it back every year for a safety check. Its just such a good deal id hate to pass it up. Ill call the State and local smog place and see if they could give me any info.
Thanks Guys!!
Old Nov 6, 2013 | 05:22 PM
moe7404's Avatar
it just came to me trucks had a different smog requirements in the early days. and some people in the early days would buy a truck instead of a car.
Old Nov 6, 2013 | 06:28 PM
I would check with a local smog guy... He should be able to tell you what it should have on it....
It might be worth putting a few bucks in as a project....
Keep us posted....
Old Nov 6, 2013 | 08:30 PM
Another thing you could do is to register it to your property address with the Ca plates no inspection. I think it has to already be in your name. Had a Hyundai belonging to a friend, who lives in Texas Car had Ca plates and a Texas address, did not require any more inspections
Old Nov 6, 2013 | 10:07 PM
Sort of............
Only 3/4T and for a few years so called "heavy 1/2 tons" which were designed to circumvent smog laws by design.
Depending on the state he's in, the smog test, requirements for equipment inspection, I would not touch this thing.
One thing many of us tend to forget that it is illegal under FEDERAL U.S. law to remove ANY smog equipment from ANY vehicle regardless of state or year model. It's just that (at least yet) there's no agency which actively enforces this, beyond individual states.
Some states are pretty reasonable, dropping older vehicles off "the list" as they get older. Some states are NOT, requiring full blown equipment in any area that applies. As these girls get older, this is going to be more difficult to be in compliance.
So far, in my area, no such problems.
Old Nov 6, 2013 | 10:49 PM
ctdfan's Avatar
I will be sure to ask about that when I call tomorrow. That would be awesome!!
Old Nov 7, 2013 | 03:52 AM
Another option is black market or find someone with another 78 Ramcharger that you can borrow. Did that years ago with my 67 Coronet
Old Nov 7, 2013 | 09:44 AM
Most the guys with Ramchargers that I’ve asked about smog in CA say the techs have no clue what they are looking at so they do the idle test and pass 'em. That’s what I’m hoping happens to mine because it’s about time to go to the ref.
I can’t believe they make us smog this stuff; the year should be 1980 and up.
Old Nov 7, 2013 | 12:22 PM
The ref will do nothing if equipment is missing. There is a cut off date for the smog requirements. But NOT when transferring owner ship as I recall.
Old Nov 7, 2013 | 04:01 PM
ctdfan's Avatar
Called the State DMV and they told me all I need to do is a 1 time initial smog check(found a local place that will pass it for $100) and when I register it I use my Missouri address and I will never have to smog again. So I go pick it up Saturday!!! Thanks Guys!!!
Old Nov 7, 2013 | 05:44 PM
Happy for you.......
ics:
Old Nov 9, 2013 | 11:05 AM
Yessssssssssss, we like pictures.
Robert Weaver
13
Sep 29, 2014 11:33 PM
dodge_dudetx
Aug 7, 2012 02:37 AM
dodge_dudetx
Mar 18, 2011 12:17 PM
mach3107
Feb 9, 2011 01:12 PM
CAT-TECH
Jan 17, 2008 06:33 PM
