1987 dodge d100 5.2L
Old Mar 27, 2020 | 03:47 PM
Timothy's Avatar
Looking for some help. The truck runs but hard to start as it takes multiple times of cranking but the issue I have is when in idle you can press the gas and it will throttle up fine. When driving of I press the gas the engine try’s to die out until I let off the gas. It looks like the exhaust is straight pipe so no converter is on it. Also a 4 barrel carb was put on it. I am trying to give any relative information about this as possible. Thanks for any ideas.
Old Mar 27, 2020 | 08:32 PM
Check for cracked and leaking vacuum hoses... Check the fuel pressure and mite change the fuel filter.... May need a carb overhaul if the Accelerator Pump is not working correctly. Timing may be an issue also.
Keep us posted...
butch
Jan 22, 2020 12:55 PM
chlngr1970
Dec 9, 2013 05:49 PM
Mudslinging
Sep 16, 2012 02:30 PM
Barz813
Jul 16, 2010 07:54 AM
Barfly
May 5, 2010 05:53 PM
