1988 Dodge W100 looking for the best fan to throw on it.
Old Oct 15, 2020 | 08:22 PM
aberndt95's Avatar
Just got a new motor in it with the holley EFI as well as radiator, waterpump, and thermostat. Looking for the best fan to keep this thing cool, as the old heads were cracked from over heating (before I got the truck)
Old Oct 16, 2020 | 02:39 AM
Archer's Avatar
ab -
If your electrical system can handle it, you're not going to beat dual electric fans, and the bigger the better.
While certainly debatable, a modern clutch fan waste less HP, and a huge flex fan does a pretty good job of cooling.
(The flex fan looks cooler too )
Proper shrouding and adequate water flow assumed in each application.
I prefer a 160* stat as well, and NOT a Mr. Gasket one. The garden variety Stant works much better and is more reliable.
And in a worst case scenario, "wet water" additives can help.
Old Oct 16, 2020 | 11:28 AM
Check with Charlie over in Holiday FL. >>>>>>> Old 02-02-2014, 05:22 PM
68hemidart
68hemidart's Avatar
Thumbs up re: aluminum radiatorsI have priced all the aluminum radiators @ 365.00 + shipping, A-B-C-E mopars, small or big block engines.
Transmission cooler is built in just like the factory radiators, and there are brackets built in for the fan schrod.
Please feel free to call me @ 727-271-5068
MOPAR CHARLIE
7 days a week 9am-6pm
located in sunny florida
thanks for the replys, and thanks for the ad
Old Oct 16, 2020 | 03:15 PM
Archer's Avatar
ab -
One other thing. While a fan is an major cooling factor, especially at idle, if your engine is/was over heating, ya might want to see what else might be causing it. Max cfm through the radiator won't help if there's a blockage somewhere somewhere else, even timing can and will cause over heating.
raycan2
Feb 18, 2014 08:13 AM
fmmurk
Aug 8, 2013 06:32 PM
440-4x4
Aug 14, 2011 04:46 PM
Cazbah362
Jun 12, 2011 01:05 AM
mikeynags
May 3, 2010 06:45 AM
