408 Build!!!!
Old Jun 13, 2010 | 01:31 PM
Moparfever4everr's Avatar
Junior Member
408 Build!!!!
I want to build a 408 for my 86 dodge, I want it to be more of a stump puller than a screamer though. I also want to be some were around 11-13 mpg with 400hp. I was going to go with a 670sa holley and either the eddi performer or the rpm not sure yet. For heads i was looking at some RHS X heads with 1.92 or 2.02 valves from hughes.
I have a set of mopar 1.5 roller rockers that would be sweet with a roller cam but there very spendy and Idk how hard it is to convert from a flat hyd to a roller hyd? Either way I'd like to get a cam with a healthy idle but good torque. I was going to go with summits cast scat stroker kit W/ I beam rods and forged dished pistons. I dont plan on F.I. in the future so I think cast w/I beams would be safe to 450 hp at 6,500 but I dont plan to wring it past 6k. Should I bolt or stud the caps and heads? Whats the advantage of the two?
I guess I just want some opinions and prefrences with building a 4x4 408 with affordable everyday economy and still put chebys and lil annoying rice burners in there place.
Old Jun 13, 2010 | 02:06 PM
You're going to want to build it with a power rang of idle to 5500/6000 RPM. A good RV cam and set of alum heads, shorty headers, 2000 RPM stall convertor, HD shift kit and at least a locker in the rear axle.
What motor are you starting with?
DreamDrager67
Apr 4, 2012 06:25 PM
bentman
Feb 1, 2011 07:04 PM
jdcarnathan
Jul 5, 2010 01:02 PM
bentman
Jul 1, 2010 06:49 AM
mod381
Nov 25, 2009 08:58 AM
