76 W100 no start, no idea
Old Aug 17, 2021 | 03:18 PM
RockATonk's Avatar
I've got a '76 W100 318 that will not start. The truck drove a few months ago and then all of a sudden when i hit the ignition button it didn't do anything. The starter refused to turn the flywheel so i replaced that, didn't work so i replaced the starter relay, didn't work so i had the battery tested, all good, full charge.
Brand new starter, relay, battery, ignition coil, distributor, and ballast resistors, but when i try to start the starter simply makes a single "thunk" sound and thats it. Even when i short out the terminals on the starter with a screwdriver it does the same things, "thunk" and no turning. Right now its a very expensive lawn ornament and i don't know much about the electrical systems in older vehicles.
If this questions has been ask/answered in the past then i apologise for double posting.
Old Aug 18, 2021 | 10:28 AM
crazy question, but have you traced aaaaaaaall the wires to make sure they are good and tight? any fuzzy stuff up by the battery terminals? sounds like a loose or corroded connection to me.
Old Aug 18, 2021 | 06:59 PM
RockATonk's Avatar
I've been trying to trace wires but the previous mechanic seemed to like spending money on electrical tape. There are groups of wires taped together that do not need tape, even a wire i found not connected at either end. The battery terminals are squeaky clean, brand new battery and terminals.The lights and wipers work fine when connected, just the starter not rolling.
Old Aug 19, 2021 | 08:22 AM
hmmm may be best to bench test the starter then, to be sure. these issues can be a bear but there's only so many things that can be wrong, so hang in there!
Old Aug 20, 2021 | 06:47 AM
Put a Socket and a Breaker bar on the front crankshaft nut and see if you can turn the engine over?
Old Aug 20, 2021 | 08:51 AM
lol good ole hog, with great advice. yeah. no use trying to trace a starter issue if the engine is seized. good call, man.
64Imperial
Oct 18, 2016 05:07 PM
duster3
Oct 2, 2013 02:46 PM
ahrkar
Sep 18, 2012 10:27 AM
Steffany
Aug 20, 2012 09:44 PM
mr_Sancho1324
Feb 3, 2011 09:05 PM
