82 lean burn replacement
Old Apr 10, 2020 | 09:18 AM
lugnutz426's Avatar
My son has an 82 d100 slant six with original lean burn. It is giving intermittant so spark and we are going to change over to regular mopar ignition module or maybe a gm hei module. Question is will the OE lean burn distributer work well with the conversion or should we change it out for a regular electronic ignition distributor. Thanks
Old Apr 10, 2020 | 10:18 AM
The distributor will not have mechanical or vacuum advance mechanisms so should be changed.
Old Apr 11, 2020 | 06:30 PM
The absolute simplest way is to use a pionts distributor .
Old Apr 12, 2020 | 09:37 AM
I recommed going something like this route myself...
https://www.jegs.com/i/JEGS/555/40500K/10002/-1
Old Apr 12, 2020 | 02:15 PM
/6 Bob
Old Apr 12, 2020 | 06:31 PM
Conversion kit for the 6 cylinder will work just fine...
But thanks for taking the confusion out !!! Point Well Made...
Old Apr 13, 2020 | 05:24 AM
I looked for the /6 convertion awhile back and couldn't find it.
Old May 14, 2020 | 02:06 PM
longtimecoug's Avatar
I have the same truck, had the same problem the distributor need to be changed
Old May 15, 2020 | 01:13 PM
You need a non lean burn distributor .....
chykov's76doba
Aug 15, 2013 01:27 PM
MrOldart2U
May 11, 2012 11:36 PM
edemestihas
Dec 30, 2011 02:25 PM
heminate
Oct 1, 2009 02:10 PM
Commando
Nov 21, 2007 05:02 AM
