83 dodge 318 dies once it warms up
Old Jan 14, 2014 | 10:25 PM
Jim Dandy's Avatar
My 83 dodge prospector with 318 runs good untill it warms up ,after 4-5 minutes starts to sputter like running out of gas.I have new fuel pump and glass filter,and can see plenty of fuel in filter,has electric choke that seems to be working properly,flap shut when starting cold and opens to straight up and down when it warms up.I have new eldebrock 4 bbl intake and carb,new wires ,timed at around 12 degrees btdc.runs good for a few minutes in drive ,and once it starts to act up wont pull itself up drive-way.anyone know what this could be ?thanks JD,
Old Jan 15, 2014 | 05:50 AM
Sounds like it is running out of fuel. I would say re-check the float level.
Old Jan 15, 2014 | 03:52 PM
unforgiven78's Avatar
An engine only needs 4 things to run. Air, fuel, ignition, and compression. Figure out which one of those is absent and youll find your problem. I would start with the ignition since most heat dying issues are traced to coils or other electronic parts.
Old Jan 15, 2014 | 07:27 PM
Jim Dandy's Avatar
thanks for your time and information Racerhog and Unforgiven78,on my 83 dodge.I will let you know the problem as soon as I can get back to work on truck.
440lives
Dec 5, 2009 08:37 PM
05ramjsp
Apr 19, 2009 03:45 AM
Cudafever
Feb 4, 2009 09:36 AM
Monacoman
Sep 21, 2008 04:15 AM
Zach8200
Feb 29, 2008 12:07 AM
