87 W250 Driveshaft specs
Old Jul 8, 2022 | 01:33 PM
lmader's Avatar
Question 87 W250 Driveshaft specs
So my rear driveshaft snapped yesterday and I was trying to find replacements on summit and I was wondering if this would be a good choice
https://www.summitracing.com/parts/axe-2583t351052
Old Jul 9, 2022 | 06:54 AM
Cheaper at a wrecking yard
Old Jul 9, 2022 | 11:49 AM
lmader's Avatar
I know it's cheaper, but I haven't found any at a boneyard
Old Jul 10, 2022 | 06:48 AM
Do you have a driveline repair shop near you? Look for one that works on Large truck heavy duty repair. Sometime they know where to get driveshafts made...
But if not.
What you do... With the vehicle sitting on the ground. Insert the yoke in the trans and pull it out 1/8 to 1/4 of an inch, measure from the center of that eye to the center of the differital eye, Give that measurement to whom ever is going to make your driveshaft and you should be good to go. Please note: you may need to give them both front and rear flange dimensions as well to get the correct U-Joints.
>>>>> https://www.iedls.com/
>>>>> https://www.iedls.com/Request_for_One_Piece_Driveshaft
Hope this helps.... Good Luck... Cheers
Old Jul 10, 2022 | 07:26 AM
lmader's Avatar
Thank you for the help
lugnutz426
Apr 12, 2020 09:32 AM
shone190
Nov 16, 2014 09:18 AM
btberte
Sep 5, 2013 09:31 PM
67 GTX
Sep 6, 2008 07:30 AM
ccflash22
Nov 12, 2007 04:22 PM
