93 dodge d150 rough idle
Old Aug 30, 2018 | 03:03 PM
demott128's Avatar
I have a 93 dodge d150 with a 318. While the vehical is in park it the idle bounces up and down. To the point it almost shuts off. Sometimes it does when I go to put it in reverse or drive. Once I'm in drive she will run good. It has a new coil pack, new distributer, new tps sensor, new plugs and wires. Is it possible that it is a timing issue?
Old Aug 30, 2018 | 06:25 PM
Look in the Idle Air Control Area. IAC maybe acting up?
Old Aug 30, 2018 | 06:37 PM
I agree with Bob!
Old Aug 31, 2018 | 01:38 AM
demott128's Avatar
Forgot to mention that, the idle control valve is brand new also.
Old Aug 31, 2018 | 08:34 AM
What are the list of engine codes it is giving you?
Old Aug 31, 2018 | 04:37 PM
demott128's Avatar
If I remember correctly it was 12 23 55. I will double check once I get a chance
Old Aug 31, 2018 | 07:11 PM
demott128's Avatar
Just went and double checked, code is 12 22 55
Old Aug 31, 2018 | 09:42 PM
demott128's Avatar
So I looked up code 22, it's the coolent temp sensor. Now could that really make my truck idle rough in park?
Old Sep 1, 2018 | 10:28 AM
The coolant sensors on those control the timing also in some cases.... Fix the codes and I think your problems will mostly go away...
Old Sep 4, 2018 | 04:04 PM
demott128's Avatar
Well I replaced the coolent temp sensor and the problem is still there. The connector doesn't look the best. It is a little loose fitting. Does anyone know where I can get a replacement connector? The wires look good.
Old Sep 6, 2018 | 05:56 AM
CHeck with your local parts house and see it they can order that pigtail? As for the Coolant sensor, Dude, Thats just throwing parts at the thing to try to fix it !!!!! You need to test the Circuit and the values in a repair manual..
Old Sep 6, 2018 | 09:52 AM
demott128's Avatar
The truck sat for 8 years, so replacing sensors does not bother me. My local shop can't get the connectors.
Old Sep 7, 2018 | 09:02 PM
Does it look like this one??????
https://www.partsgeek.com/c7l7tyw-do...ad=11620898016
Old Sep 7, 2018 | 09:13 PM
demott128's Avatar
No I've looked at that one. When i get a chance I will take of picture of mine.
Duster_Dude
Aug 27, 2017 07:49 AM
mobilejoe
Jul 12, 2013 02:24 PM
driftlee
Jun 8, 2013 02:05 PM
dodgenut7
May 22, 2011 11:55 AM
TALudwick
Aug 30, 2008 04:26 AM
