advanced timing on my W200 camshaft
Old May 11, 2021 | 07:14 AM
rdyksman's Avatar
Hello,
I am currently rebuilding my ' 318 76 W200 engine. I bought a new camshaft (Sum-6900) for more torq. I have a performer intake and a edelbrock 1406 carb with headers.
With the timingset i bought i can advance or retard the cam compare to the crankshaft. I am planning to advance 4 degrees to add torq a low RPM .
The W200 4X4 (ex us-army )won't be in the high RPm's .
Is this a good idea and is 4 degrees a good number
Hope you can give me some advice
regards robbert
netherlands
Old May 11, 2021 | 08:12 AM
I usually go for 2° advance on most applications just too compensate for timing chain stretch.
how big is the cam?
Old May 11, 2021 | 08:20 AM
Is this your cam? https://www.summitracing.com/parts/sum-6900/make/dodge
I don't think it needs to be advanced more than 2° it should work good straight up.
Old May 11, 2021 | 08:30 AM
rdyksman's Avatar
Yes thats the cam so 2 degrees? With the new chain there shoud be no stretch
Old May 12, 2021 | 04:29 PM
New chains always stretch, the 2° may or may not be enough to compensate, it's just what I do.
Old May 27, 2021 | 09:06 AM
stroller's Avatar
I use MOPAR performance off set keys ways to do this. I have the mopar engine book 8th edition. I have a 360 I did the 4 degree BTDC so the cam will come alive before 2500 rpm and the torque at lower rpm, basically for towing and hauling.
Old May 28, 2021 | 07:43 AM
I myself would just run it Straight up.
Note: you will gain more just by going with a 0-Deck pistons on your rebuild.
just my 2cents
cmrris
19
Nov 3, 2017 07:07 AM
Joel Carvalho
Oct 8, 2015 12:26 PM
joelevelis@comcast.net
Sep 13, 2013 08:46 AM
74-D100
Aug 17, 2011 02:23 PM
SPICOLIE203
May 1, 2011 10:44 AM
