Clattering sound from bottom end
Old Apr 19, 2025 | 09:38 AM
Scuzzlebutt's Avatar
89 W150 318/727
At idle the bottom end sounds like the clatter of a diesel engine. It goes away when I give it gas. Wondering what you folks think it might be?
For the record: Fresh oil (60 psi when cruising and 25 psi at idle, vacuum gauge reads 18.5 at idle, and all cylinders have about 120 psi compression.
Old Apr 19, 2025 | 10:51 AM
You could have a rod bearing or two going bad or a thrust bearing bad alowing crank to move forward and back making things come in contact with each other.
Old Apr 19, 2025 | 11:49 AM
Other than being a mess, there isn't really a reason why I couldn't replace the thrust and rod bearings while the engine is still in, right? My truck is 4wd and has about a 3 inch suspension lift so I should have plenty of room as well.
Old Apr 20, 2025 | 07:29 AM
Providing the crankshaft is ok and not scared or you haven’t spun a bearing you can replace the rod and main bearings in the truck, I’ve done it before.
The rods are fairly easy but the mains will need to be rolled into place, that is the upper bearing. You pull the main caps and let it hang on the timing chain torque converter. Sometimes the upper main will move when you rotate the crankshaft but most you will need to be pushed around in the direction of the tab that holds them in place.
before I would tear into it I would make sure to verify that it was the actual problem, with it running making the noise and the truck in park and park brake on get under it and try to isolate the noise torque converter bolts hitting the block or tins, timing chain or whatever it is.
good luck
Old Apr 20, 2025 | 08:27 AM
Sounds like you just need to open it up and check to see whats up and go from there.... Keep us posted.... Hope its a simple fix for you... Cheers
chphlds
May 14, 2019 09:04 AM
b7labelle
Dec 29, 2013 04:13 PM
dodgenut7
May 19, 2010 05:09 PM
joelevelis@comcast.net
Oct 18, 2009 07:15 AM
TALudwick
Aug 30, 2008 04:26 AM
