Does anyone know what the ohm value is for the fuel sending unit
Old Dec 6, 2011 | 10:39 AM
pityocamptes's Avatar
For a 1989 W250 w/360? I'm having a hell of a time finding the fuel module so I will probably R&R the whole thing. I was going to replace the sender unit in the tank, but I can't find anything, online or local. I guess I can clean it up and pray that it works. Does anyone know the ohm value for the sending unit for this year and model? Thanks!!!
Old Dec 6, 2011 | 12:15 PM
John Van's Avatar
Chrysler and ford use the same values,I know a few people who just used a ford sending unit and adapted it to fit. Here's a link that might help:http://www.fordification.com/tech/fu...ding-units.htm
good luck,john
Old Dec 6, 2011 | 01:15 PM
good luck,john
Thanks!!! I am confused, on the chart:
Ohms/Resistance Popular Models
(Empty/Full)
0-90 Ohms _________________most GM cars, 1965-up
73-10 Ohms ________________pre-1989 Fords & most Chryslers
240-33.5 Ohms______________Industry standard, works on many popular cars
0-30 Ohms__________________most pre-1965 GM cars
16-158 Ohms________________most '89-up Fords
So should I assume a 240-33.5ohm for the 1989 w250 sending unit? Thanks!
Old Dec 6, 2011 | 01:38 PM
John Van's Avatar
(Empty/Full)
No, the 73-10 ohms = most chryslers. Also make sure you have a good ground!
john
Old Dec 6, 2011 | 03:22 PM
Carb= 5-8ohms full, 60-75ohms empty.
F.I.= 120ohms full, 10ohms empty.
Old Dec 6, 2011 | 03:42 PM
Thanks! I'm sort of in the middle with TBI... so would it be the FI specs?
Old Dec 6, 2011 | 03:49 PM
TBI= F.I. Yes. These numbers are from my manual.
Old Dec 6, 2011 | 03:51 PM
Thank you! Hopefully I can find an aftermarket/universal sending unit that will work. Any ideas or sources? Thanks again!
Old Dec 7, 2011 | 11:50 AM
John Van's Avatar
Coronet, Thanks for the info!! I still can't get use to the new stuff!!
john
Old Dec 7, 2011 | 01:51 PM
You Sir, are very welcome. Like I tell my boys, if you can read you can fix just about anything.
Old Feb 3, 2018 | 04:12 PM
Brutus's Avatar
Carb
So I saw your post, so in my case I have a carb, so what does that mean for me if the gauge is only at 10 ohms full but for my carb it needs to go to 5-8?
Old Jan 10, 2020 | 11:07 AM
Cody Lasley's Avatar
trying to figure out specs for a 88 dodge d100. All the sending units are discontinued and im putting a fuel cell in the bed Of the truck with an inline fuel pump. Need to know fuel pressure for it and ohm specs if you have them sir
Old Feb 10, 2020 | 03:30 PM
Red Freight train's Avatar
Do you try LMC truck? I know they have quite a few different ones. They are on page 44 of their current catalog.
good luck
Old Aug 8, 2020 | 10:19 AM
Ted Joyce's Avatar
I heard somewhere that corrosion gets into the contacts and connectors and kills the signals to the dash. I’m just getting ready to TS my fuel sender issues and that’s where I intend to start. I’m taking the box off so I can get at everything for a 4 link mod anyway... might be a simple fix.
Robert Weaver
May 31, 2014 05:40 AM
Aspen
Aug 31, 2009 10:28 PM
mopar nate
Jan 25, 2009 09:12 AM
Aug 4, 2008 01:26 PM
64fury
Jun 16, 2008 12:40 PM
