dropping oil pressure
I would use a mechanical gauge to measure the pressure as those are usually more accurate than the electric sending units. Just something that I have noticed over the years.
One thing could be causing the issue is that the oil pump may need to be rebuilt.
Have this issue with my 95 318 magnum, 257k miles. Around 180k I started getting low, and fluttering at idle, oil pressure. I've also had a bad head gasket forever[used to foam the oil], but I think it sealed itself by now! Changed the oil pump at about 230k, no joy. Saw anti-freeze dripping from one of the cylinders and off the crank, oh well. Since then I have been using the Lucas oil treatment or 20w-50 to maintain oil pressure. Yeah, just a band aid, but at this point no sense in rebuilding it. I'll just wait till it blows and toss in another used 5.2, they made a gazillion of them, not hard or expensive to find.
bengibbard13@gmail.com
Mar 13, 2014 07:26 PM
krublee
Jan 2, 2011 11:02 AM
dzltd02
Oct 28, 2008 08:25 AM
