dropping oil pressure
Old Nov 30, 2010 | 01:45 PM
bltpls5's Avatar
92 318 w150; I am not sure the pressure, but it starts at the first line from the left when its cold and as it warms up it drops alittle
Old Nov 30, 2010 | 02:10 PM
well, oil pressure will drop when the car heats up
the oil gets thinner, so pressure drops
how much of a pressure drop occurs?
Old Nov 30, 2010 | 02:33 PM
blue 68 gts's Avatar
Yep.. oil pressure drops as it warms up..
Running oil something like 20w50 will help increase oil pressure.
Get an aftermarket gauge to see what your oil pressure is in PSI.
Old Nov 30, 2010 | 03:35 PM
bltpls5's Avatar
that was my next step with the gauges. I just thought it started off kinda low
Old Nov 30, 2010 | 03:37 PM
bltpls5's Avatar
At what pressure should i start being concerned
Old Nov 30, 2010 | 06:49 PM
If it starts falling under 15 psi when warmed at 1,000 RPM
Old Dec 1, 2010 | 03:30 AM
I would use a mechanical gauge to measure the pressure as those are usually more accurate than the electric sending units. Just something that I have noticed over the years.
One thing could be causing the issue is that the oil pump may need to be rebuilt.
Old Dec 1, 2010 | 02:33 PM
the general rule is 10lbs per 1000 rpm
Old Dec 1, 2010 | 04:35 PM
scotts74birds's Avatar
Have this issue with my 95 318 magnum, 257k miles. Around 180k I started getting low, and fluttering at idle, oil pressure. I've also had a bad head gasket forever[used to foam the oil], but I think it sealed itself by now! Changed the oil pump at about 230k, no joy. Saw anti-freeze dripping from one of the cylinders and off the crank, oh well. Since then I have been using the Lucas oil treatment or 20w-50 to maintain oil pressure. Yeah, just a band aid, but at this point no sense in rebuilding it. I'll just wait till it blows and toss in another used 5.2, they made a gazillion of them, not hard or expensive to find.
Skynyrd
Sep 10, 2014 05:24 PM
bengibbard13@gmail.com
Mar 13, 2014 07:26 PM
Tiffany
Sep 14, 2011 10:45 AM
krublee
Jan 2, 2011 11:02 AM
dzltd02
Oct 28, 2008 08:25 AM
