gas tank.
Old Mar 12, 2018 | 10:23 PM
Bertmann73's Avatar
gas tank.
I have a 75 d200 club cab long bed and the plastic undercarriage tank is a lost cause. does anyone know where to find a replacement tank?
I have been looking on line and only find the chevy tanks. has anyone tried to use one of these??
Old Mar 13, 2018 | 05:31 AM
Try these guys>>>>>> http://www.dodgeconnection.com/DodgeConnectionHome.html
Old Apr 16, 2018 | 10:36 PM
Bertmann73's Avatar
thank you.
sorry so late. been busy. i didn't find it on the website but i sent them a part request.
hope fully they can find something or at least point me in the right direction.
Old Apr 17, 2018 | 05:14 AM
ZEN357's Avatar
Call Jegs Performance or Summit Racing. I'm sure someone can help you there.
Old Jun 6, 2018 | 02:24 PM
GoGoMacho's Avatar
I have a long bed plastic tank frame mounted. It is in good shape. I'm will to sell but very expensive due to rarity as your finding. I'm in San Diego and would want $450.00 plus shipping. I've repaired these using a special 2 part system made by 3M. It works well on poly tanks. Silicone does not work for long.
Old Sep 28, 2018 | 10:39 AM
George Az's Avatar
I know this post is a little older, but I put an RCI fuel cell in the bed. Seems like this is occurring more and more as those plastic tanks go kaput. At the last car show I attended, I saw several trucks this way. You do loose a little bed space. I have a tool box in mine and cut a hole through it so the tank is hidden. I have to lift the tool box lid to fill up, but I have had zero issues with the fuel system since this happened. get a brand new 19 gal fuel tank for a couple hundred dollars. You can go bigger or smaller. They have a spare tire area mount if you want to cut a hole in the bed for the filler cap and that looks pretty cool too.
Old Oct 5, 2018 | 06:49 PM
Rod1701's Avatar
Having the same trouble
PO put in a fuel cell. I really don’t like it backside it takes up about 1/3 of the bed since it’s a short bed stepside.
Getting a a couple of local leads but having trouble conn vying with the seller. $450 sounds steep BUT there aren’t many out there. May not be bad since most of the others are pull from a salvage truck and plastic may disintegrate when your touch it.
66Newport
Nov 18, 2021 09:46 AM
djr0818
Jul 10, 2021 04:59 AM
aceofspades
Jun 3, 2014 08:58 AM
68camperspecial
Jul 25, 2009 07:15 AM
71RR08
Aug 25, 2008 08:40 PM
