LA 360 Thermostat Question
Old Apr 19, 2020 | 07:11 PM
Tau511's Avatar
Been trying to figure this out.
I have a 1980s LA 360.
I do have an Edelbrock EPS intake - which should take a stock thermostat.
I have a replacement thermostat housing that looks like stock.
I ordered what I believe is like a 53 mm or something thermostat from Summit (listed as stock size). It is way smaller than the thermostat I have from the engine before which is a 63 mm (didn't check prior to ordering - whoops). The smaller one fits fine on the intake but there is so much open space in the housing that it concerns me - like it might bounce around or something. I do have the gaskets both in place - still seems like it MIGHT be loose.
Do I need to find a different thermostat? I feel crazy but I'm actually struggling to find a 63 mm thermostat.
Thanks.
Old Apr 20, 2020 | 05:42 AM
Up to 1978 is the larger, after is the smaller. The recess to hold it is in the housing, GM has the recess in the manifold. Aftermarket manifolds could be either and some put a Chev housing on which will bolt on but have the thermostat rattle and have a loose gasket edge which could break off and block flow. Take the time to get the right stuff.
Feb 22, 2018 06:42 AM
josehf34
Jun 5, 2014 06:12 AM
jimiheadstone
Oct 2, 2013 04:03 AM
bushwood
Oct 26, 2011 03:46 PM
68 Sat
Oct 27, 2008 12:31 PM
