Lowering Kit for 1989 D150 2WD
Was told by a "reputable" source that a lowering kit for a '83-'97 Mitsubishi Mighty Max will fit my '89 D150...is this true? If so, didn't know Dodge and Mitsubishi were the same. If not, does anyone know of a lowering kit that will work?
No it won't work. The Mitsubishi Mighty Max is comparable to the 1st gen Dodge Dakota (compact truck), not the D150 (1/2 ton full size). The suspension components won't handle the weight of the D150.
Take a look at some earlier posts in this section that I've made up. One should be about how to lower your D150.
You can get lower arms on ebay JUST make sure to get 1/2 T . that should get you the correct lower ball joint size
http://www.ebay.com/itm/DODGE-VAN-LO...96f061&vxp=mtr
