Lowering Kit for 1989 D150 2WD
Old Oct 9, 2013 | 06:13 PM
my89mopar's Avatar
Cool Lowering Kit for 1989 D150 2WD
Was told by a "reputable" source that a lowering kit for a '83-'97 Mitsubishi Mighty Max will fit my '89 D150...is this true? If so, didn't know Dodge and Mitsubishi were the same. If not, does anyone know of a lowering kit that will work?
Old Oct 10, 2013 | 12:25 AM
slade's Avatar
mitsu abd dodge have always had a relationship. have u looked at belltech. or western chassis? they may make one. ive see them lowered. mabey a new style ram stuff would work like 94-03? i think
Old Oct 10, 2013 | 12:47 AM
slade's Avatar
is the leaf spring under or over the rear?
Old Oct 10, 2013 | 02:23 AM
No it won't work. The Mitsubishi Mighty Max is comparable to the 1st gen Dodge Dakota (compact truck), not the D150 (1/2 ton full size). The suspension components won't handle the weight of the D150.
Take a look at some earlier posts in this section that I've made up. One should be about how to lower your D150.
Old Oct 10, 2013 | 02:24 AM
Here it is......
https://moparforums.com/forums/f96/h...-pickup-15136/
Old Oct 15, 2013 | 07:09 AM
DustinHeck's Avatar
just look at mine that's how I did it
Old Oct 15, 2013 | 01:21 PM
You can get lower arms on ebay JUST make sure to get 1/2 T . that should get you the correct lower ball joint size
http://www.ebay.com/itm/DODGE-VAN-LO...96f061&vxp=mtr
Old Oct 31, 2013 | 06:23 PM
DodgeAddict's Avatar
My RC uses 78-98 Van LCA's & rear axle flip
Attached Thumbnails Lowering Kit for 1989 D150 2WD-sam_0268.jpg   Lowering Kit for 1989 D150 2WD-sam_0269.jpg   Lowering Kit for 1989 D150 2WD-sam_0271.jpg
8287rams
Dec 28, 2010 11:26 PM
patricklyle77
Sep 13, 2010 08:45 AM
nater
Jun 2, 2010 02:48 AM
kansas d150
Jan 17, 2009 04:48 PM
patricklyle77
Jun 13, 2007 09:47 PM
