Motor swap
Old Jul 31, 2023 | 05:51 PM
Flogrown's Avatar
Motor swap
I recently picked up a 1975 Dodge Power Wagon W200 single cab, LWB, manual transmission, 225 slant six, full time front end, no ac.
Looking to junk the slant six and put a V8 in but want to use the same bell housing and motor mounts, anyone got some info on a possible candidate, I’m not very familiar with the Dodge trucks?
Thanks
Old Jul 31, 2023 | 07:04 PM
Your going to need V8 mounts big block or small block and bell housing big or small block, just the way it is…
you will also need motor mount frame brackets and motor brackets. The oil pans are different between cars and trucks so you need a truck pan…
Make sure the crank shaft on the new V8 is drilled for pilot bearing, some are and some aren’t plus you need the correct flywheel for the new motor because the/6 will not work.
Old Jul 31, 2023 | 07:18 PM
It would be much easier to swap the complete power train from a newer late 90s truck.
Old Aug 1, 2023 | 04:06 AM
Kuvasz101's Avatar
Chrysler swaps are non-forgiving. It would be easier putting an Edsel v8 in place of what you're planning to do.
Old Aug 1, 2023 | 08:06 AM
Flogrown's Avatar
Motor Swap
Sounds like I need to stick with the slant then, yall know anyone that sells a complete bebuilt engine manifolds and all?
thanks
Old Aug 6, 2023 | 02:17 PM
Hahahahahaha..... True.....
Austin s
Jan 4, 2023 04:15 PM
Beeboy
Oct 30, 2022 12:15 PM
Gene75D100
May 4, 2018 02:04 PM
mopar2719
Dec 6, 2010 03:17 AM
hollowking
Apr 6, 2009 02:38 AM
