Need a new carb for a 1974 D200
Old Feb 22, 2014 | 02:41 PM
D200powerwagon's Avatar
It has a Holley 2 barrel that can't be rebuilt. The fuel inlet is stripped and it leaks fuel bad. I've tried soldering it and then JB weld which only worked for a while. The carb reads: R 6485 A
3698385
1033
Anyone know what model this is?
Also, since I only use it as a plow truck, I'm thinking of a 4 barrel replacement for more power. Will I get more power and how much?
Could somebody please tell me a model # that will bolt right on and all the hoses and linkage will work too?
Old Feb 22, 2014 | 03:23 PM
moe7404's Avatar
have i ever said toss the holley? oh yea i did. my idea is use as much O.E.M. parts as you can.
Old Feb 22, 2014 | 03:40 PM
What on earth do you mean? The Holley IS the origenal carburator.
Old Feb 22, 2014 | 03:55 PM
R6485A should be the number unless the carb has been changed.... But if it has not.... Try Napa auto parts.... Try the Tomco carb web site.... Carb Doctor...
Just to name a few...
Old Feb 22, 2014 | 06:24 PM
moe7404's Avatar
OH sorry i think i know which carb you have. it is not a bad carb. but generaly the O.E.M. carters are better. if that is the carb i think it is i think they made lots and lots of them i might even have one like yours. but finding it will not be easy. the carb doc that racer listed is a good shop. ill bet racer can tell you more about that carb than i can. just dont over tighten the fuel fitting. they use a very fine thread not good for a carb. cause the metal used on that carb is not as strong as a other carbs, I.E. AFB.
Old Jan 23, 2020 | 12:27 PM
RCCadman's Avatar
3698385
1033
The carb you have is the Holley 2210. Search for a carb with that number. The 2209 might fit, and the 2245 that I have could possibly be the same.
https://www.carburetion.com/CarbNumber.asp?Number=R6485
https://www.carburetor-parts.com/Holley_c_26.html
Old Jan 24, 2020 | 03:38 PM
Tau511's Avatar
To answer your 4 vs 2 barrel question:
It doesn't sound to me like you have any interest in swapping the intake so I doubt switching to a 4 barrel (assuming you were looking into an adapter or something) is really going to get you any actual power gain.
Old Dec 31, 2021 | 10:49 PM
Elamigo98002's Avatar
I put the edelbrock and high rise on mine runs just fine bolted right up
Billy P
Aug 28, 2018 07:53 PM
Just_a_spoonfull_of_Jesse
Jul 19, 2017 07:16 PM
nashvegas99
May 24, 2014 02:28 PM
g-man
Jul 23, 2011 09:39 AM
slacker200
Nov 10, 2009 03:34 AM
