wiper motor has no fuse?
Old Oct 26, 2017 | 08:40 PM
dodgem880's Avatar
I was looking at a wiring diagram for my 1977 Dodge W200. I noticed the wiper motor doesn't seem to be protected by a fuse? Why? On the actually truck I believe the only protection for that circuit would be the fusible link (in the engine compartment) or maybe the (15A?) circuit breaker (between the flashers). It appears to ****** power off a light blue wire which is the main power wire fed by the ignition switch.
The wiper motor is one of many circuits I plan to switch over to relay control but, it doesn't feel wise not to including a fuse.
So, the next question is what size fuse? I understand the motor will pull a lot of current when starting up or when locked up.
A 1986 Ramcharger calls for a 20AMP fuse... that seems like a good start.
If it blows I could up the size and carry spares... sounds better than no fuse at all.
Any suggestions?
Old Nov 5, 2017 | 07:34 AM
dodgem880's Avatar
I removed all the fuses and sure enough the wipers still run. So, other than the factory fusible link that feeds the ignition switch there is no protection that I can see.
From what I understand fusible links are more for protecting the wires than the devices connected to them. The last line of defense.
Dizzle
May 23, 2010 04:21 AM
dusterdave
Jun 22, 2009 07:30 PM
68satellite
May 18, 2009 06:35 PM
ronroddey
Apr 13, 2009 02:08 AM
DartConvertible
Jan 21, 2009 09:19 PM
