Wiring problem
Old Aug 22, 2017 | 05:37 PM
RCCRUZ1's Avatar
Wiring problem
hey there, hopefully you guys would be able to help me out here, a few months ago I bought a 83 d150 fixer, most of the dash wiring was cut and the dash was ripped out, I was able to get most of wiring put back together but I'm having some problems with the lights, I have the head lights, taillights, four ways working but I can't get the turn signals to work, I checked the flasher and it's good, I've looked up schematics but none of them show the color wires or connections that I see in the truck, I've posted a picture of the wires I have and if anyone could help me figure which wire are what that would be great, thanks in advance
Old Aug 22, 2017 | 08:31 PM
Looks to me that you have the wrong T/S switch... Just my 2 cents....
>>>>>> https://www.oreillyauto.com/detail/b...-rwd?q=turn+si
That switch looks more like a switch for a GM product..
Old Aug 23, 2017 | 04:16 AM
RCCRUZ1's Avatar
I have that t/s switch (it's on the floor board but can't see in the picture) but it barely fits in the connecter and even then I get the same results
Old Aug 23, 2017 | 06:29 PM
I'll try to dig out a wiring diagram to help....
Old Aug 24, 2017 | 04:42 PM
If it is anything like the van I had there are two flashers one for turn and one for flashers
Old Aug 24, 2017 | 06:38 PM
I printed out the wrong schematic, I'll have to look for it next week if I can remember too. Sorry... I printed the one for an 86 for some reason, Guess I have that on my mind for some reason... Sheesh...
Old Aug 26, 2017 | 01:32 PM
RCCRUZ1's Avatar
Ok racer hog, thanks for the help
Old Aug 29, 2017 | 10:27 AM
Check the # 5 Fuse for power out to the Flasher....
Old Sep 2, 2017 | 06:35 PM
RCCRUZ1's Avatar
The #5 fuse is good, so I was able to get the turn signal switch to work when the light switch is off, but when I turn on the running lights and driving lights the front marker lights flash irregular and the back ones barely flash if you really look, any idea?
Old Sep 3, 2017 | 08:37 AM
Check and clean all the grounds.... That part sounds like a ground issue too me.
rc-ltu
Feb 8, 2011 09:00 PM
RROriginals
May 8, 2010 07:33 PM
skrewball1211
Dec 3, 2008 03:56 PM
fishpwr
Sep 25, 2008 03:37 PM
dbaughman
Apr 5, 2008 08:53 AM
