MSD 6A not working
Old Aug 23, 2008 | 12:46 PM
I have heard the same. I am running a 5900 box just for the added benifits. I want to make sure that ALL the fuel that can be burned is getting burned.
Old Aug 23, 2008 | 02:23 PM
timing good? is anything getting hot, like the box or any parts of the ignition? points still good?
Old Aug 25, 2008 | 05:21 PM
challenger's Avatar
Was that the whole problem as to the spitting and sputtering also
Old Aug 26, 2008 | 12:42 AM
Originally Posted by Mixmastermerrill
No. It still sputters a little. But I can pull it up to around 4000 rpm in park. I took it for a drive. If I give it too much throttle, It cuts out. I put the timing light on the #1 CYL and noticed that the light was not picking up a signal on every stroke. It has an old destributor so I think I might need to put a new pickup and relcutor wheel I guess?
could just be the magnetic pickup isn't working right. What vehicle is this in?
Old Aug 27, 2008 | 01:01 AM
did the distributor get upgraded? it should have a points distributor if it is stock i believe.
durangogirl
Dec 11, 2012 09:25 AM
hippo204
Aug 8, 2010 12:29 PM
gilesie
Jul 14, 2008 02:29 AM
azzkikr
Feb 21, 2008 04:36 PM
Plyduster318
Sep 22, 2007 05:32 PM
