starting problem
Old Sep 30, 2008 | 06:38 PM
Commando's Avatar
Welcome to the forums.
Did you just pull the old one out and put the new one in? Was the old one points? Did you recheck the timing?
Old Oct 1, 2008 | 12:35 AM
if you can give us a link to the exact dizzy you installed, we can probably tell you what you need to do or where to start.
Old Oct 1, 2008 | 02:35 PM
http://store.summitracing.com/egnsea...256+115+400304
which one did you install? there are 6 to choose from.
what motor do you have? have you checked to see if your coil is putting out spark? do you have power going to the coil? is the rotor installed in the cap? is the dizzy spinning when the motor is being turned over?
Old Oct 2, 2008 | 04:01 PM
do you have power getting to the coil? do you have spark coming out of the coil?
Old Oct 2, 2008 | 04:56 PM
ef8340's Avatar
Senior Member
if you can tell us how you connected together the harnes that comes in the kit have the same color coded wires as factory units should have example black/yellow tracer , gray/black tracer etc etc on the electronic box it should have a plug like this
4 5 with a screw in the middle if you could tell us where you ran the wires too and we can cross refrence it for you also another thing to check could be the voltage reg i think they changed them in 72 when they went to electronic ignition plus are you using the 4 pin or 2 pin ballast resistor? either way will work but you can hook it up the 2 pin way
Old Oct 2, 2008 | 04:58 PM
ef8340's Avatar
Senior Member
argh the pin didnt show right anyhow you should get the idea
goodluck
Old Oct 3, 2008 | 12:34 AM
have you tried it with the stock coil? I have heard of brand new coils not throwing out any spark.
Gishman91
Feb 16, 2013 11:05 PM
68bird
Sep 10, 2009 03:07 PM
mopar nate
Dec 28, 2008 09:48 PM
speedtriple
May 30, 2008 03:45 AM
siliconcrunch
Apr 8, 2008 10:17 AM
