cam and lifters ?
Old 03-14-2011, 10:23 AM
rc-ltu's Avatar
cam and lifters ?
ok, so i want to replace my cam with a new one its stock right now on 73 charger 400 and i want a new one with some great power but will be used for daily driver and what not...but they have so many i want some opinions!
Old 03-14-2011, 03:30 PM
ryan's Avatar
I've used comp cams purple shaft mopar cams and hughes engines cams. If you want to stay with a stock type configuaration I'd recommend going with a comp hydrallic cam. I do really like the 284 mp purple cam, but you need to make the rest of the engine work with that like a good dual plane intake, headers, 2400 or better stall converter. its all a matter of opinion on which brand to use, but picking the size(duration, lift, and overlap-centerline) all depends on the rest of your engine set up. With more info on your set-up people might be able to give you a little more advise
Old 06-01-2011, 03:20 PM
Check out Comp Cams Camquest 6 program, plug in your combination and see what they suggest. Free to down load.
Old 06-03-2011, 08:57 PM
scotts74birds's Avatar
Just from my experience, pick one, and then go ONE size smaller!!!! An over-cammed motor is a miserable son of a bitch to deal with on a daily basis! And mine was a stick! Couldnt imagine if it was an auto!
maca
07-17-2014 03:13 PM
70newport
03-20-2014 07:52 AM
maca
03-12-2014 11:50 PM
1968GTX
31
02-19-2014 10:00 AM
1923tbucket
04-03-2013 02:15 PM
Quick Reply: cam and lifters ?
