pain in the a%% headers
I had to ding the header to make room for the tie rod end too. Any chance you accidentally knocked of the kickdown linkage while messing with the headers? That could make it slip under hard acceleration.
For Thomas: That kick down linkage controls when and how the transmission shifts in relationship to the throttle, how long it will hold a gear and what throttle position that is desired for 'passing gear' to hit. Make sure that the spring is on, to hold it forward (that's probably why it's slipping). It can also be adjusted to do what you want but then, there are ideal settings.
