Timing needed adjustment
#31
I have seen distributors that were just wore out. Check the movements and the bearings on the shaft.
#32
#33
I know this has gone on for a while so hopefully this will be my last question im thinking my main issue is the stock distributor . I was wondering what replacement you guys would recommend. Attached are the specs of my rebuild . thanks for any advice pete
#34
The mopar electronic conversion distributor with the box and wiring.
https://www.manciniracing.com/ma361383400e3.html
#35
#37
If the Motor Runs good up the RPM band to 2000 -3000... I would be looking possibly that the secondary on the carb might not be opening, If it's a Vacuum Secondary?
