a518 issues
a518 issues
hi swapping a518 into 84 dodge d 250 with la360 what do i need as far as flex plate and t/q. I have the original 318 flex plate and t/q from donor 92 dakota there is a weight on the t/q should i knock off ?
Welcome
do not knock off the weight ...you nd a tork converter for a 360. It.will have a.larger weight to balance the 360.
other than that its a straight swap
did you happen to take the lock up and overdrive wire pigtail
how will u activate them
orangesteve
27
04-08-2013 02:59 AM
maca
18
01-14-2013 04:24 AM
