Dodge Dakota misfire
Old 01-15-2017, 07:45 AM
Gator52's Avatar
Hi, I have a 2003 dodge Dakota, 3.9 engine, automatic, rear wheel drive. 174000 kms. The problem I'm having is a p0303 cylinder 3 misfire, even though I have replaced everything I can think of that has anything to do with ignition, including oxygen sensors. Compression test results are all good. Some days it won't do it but 95% of the time it does. Has anyone ever had this same problem? Any help would be appreciated and maybe slow down the greying of my hair.
Old 01-15-2017, 08:22 AM
How about the fuel injector, have you tried fuel injector cleaner?
Old 01-15-2017, 09:46 AM
In that case I would go look for a flat cam lobe on the mechanical side...
Check to make sure it is getting the juice...
And like Iowan said. Injector....
Note: you can swap some of the parts ad see if it follows, to check to see if the component is faulty or not...
Keep us posted..
Just my 2 cents
Old 01-16-2017, 01:09 AM
Could also have a bad valve spring
Old 01-16-2017, 07:34 AM
So True..
Old 01-16-2017, 07:31 PM
Could be a bad valve guide, had it happen on a Pontiac V8 twenty years ago. Sometimes the mis was there then it would be fine, finally it was more consistent and diagnosable.
duster73ply
07-10-2012 07:36 AM
Cure
04-21-2010 10:32 PM
David Blair
03-14-2010 04:48 AM
stupidnoob
01-19-2010 12:27 AM
04-05-2009 06:07 PM
Quick Reply: Dodge Dakota misfire
