440 exhaust bolt question
Old 05-11-2009, 05:19 PM
Commando's Avatar
I assume they are stock heads, the heads I pulled off my engine had access to the water jacket through each bolt hole so they all needed to be sealed.
Old 05-11-2009, 06:52 PM
i am pretty sure i sealed all of them
just do all of them for safety
Old 05-19-2009, 04:39 PM
Commando's Avatar
Keep an eye on them to make sure there is no leak, I would have used the copper RTV because of the heat, another recommendation would have been Boiler Putty, what plumbers use.
Old 02-03-2011, 09:10 PM
Foedoe's Avatar
I didnt use sealant on mine it blows a little white smoke i bet thats it
So hi temp rtv on the bolts?
Old 02-03-2011, 10:05 PM
MercuryDon's Avatar
I use Permatex Aviation also.
Old 02-04-2011, 06:58 AM
maddawg57's Avatar
I did not know that, I learn something new every day.I'm running Edelbrock RPM heads,and I just had the drivers side header off n back on, and had no leaks n still have no leaks yet.Was I extremly lucky or do the RPM head"s exhaust bolts not intersect the water jackets in the head. Thanx Bob
Old 12-04-2016, 02:21 PM
ykf7b0's Avatar
The RPM heads and all other aluminum aftermarket big block Mopar heads are blind holes and do not go into the water jackets. Only factory cast heads have this design.
Robert Weaver
09-23-2014 08:23 PM
DanK
02-26-2014 06:56 AM
Red Devil
20
04-18-2011 06:05 PM
66fury3
03-06-2011 02:31 PM
chlngr1970
08-12-2009 12:16 PM
Quick Reply: 440 exhaust bolt question
