Sponsored by:
Sponsored by:
New user help advise, 440 duster
Old 09-01-2015, 03:49 PM
Gwywnc's Avatar
Hi I am looking at a duster with a 440 in it. My question is will this engine twist the frame of this car? I have done some research and I have read that the frame needs to be welded or reinforced so that the torque of the engine does not twist the frame. Will someone that knows take a look at this and tell me if this will hold up to the power of the 440? You might have to click view discription to see the underside pics. Thank.
http://m.ebay.com/itm/Plymouth-Duster-Huge-no-reserve-on-select-cars-this-week-only-/331618011813?nav=SEARCH
Old 09-01-2015, 06:41 PM
I looked at the add and did not get the impression there was a big HP 440 under the hood. I would be more concerned about slicked over rust.
Old 09-01-2015, 06:45 PM
Gwywnc's Avatar
Old 09-01-2015, 06:47 PM
Gwywnc's Avatar
So it don't look like a big block? And how check on rust?
Old 09-01-2015, 06:58 PM
Looks very mild ? looks can be deceiving , it is definitely A BIG BLOCK.. a good set of frame connectors would be a good idea. Ties the front and rear frames together & stiffens the car..
Old 09-01-2015, 07:00 PM
With those tires no problem, they'll just spin. With traction lots of twisting.
Google search Dodge A Body Restoration and find some before pictures, they'll show the usual places to check.
Old 09-02-2015, 03:36 AM
Magoo's Avatar
Smile FRAME CONNECTORS
Jegs has Frame Connectors for $150.99 -- www.jegs.com
Old 09-02-2015, 05:03 AM
Some of the 70s 440 made about 260 hp, they refer to the car as a restoration, an over used term that could mean a rattle can paint job or it was on a rotisserie for a year.
Just be careful
Old 09-30-2015, 04:03 PM
Skynyrd's Avatar
Duster's never came with 440s , 340 or 360 or slant 6s . Someone could have put the 440 in it but if so you would think they would have also known to put frame connectors . The engine # is on the side of the block.
Old 09-30-2015, 06:55 PM
moparted's Avatar
way over priced
coronet66
07-01-2013 09:16 AM
bsfor
08-22-2012 09:05 PM
1kcent
04-16-2011 07:17 AM
Polara_68
04-22-2009 03:54 PM
rabys
06-28-2008 01:36 PM
Quick Reply: New user help advise, 440 duster
