New user help advise, 440 duster
Hi I am looking at a duster with a 440 in it. My question is will this engine twist the frame of this car? I have done some research and I have read that the frame needs to be welded or reinforced so that the torque of the engine does not twist the frame. Will someone that knows take a look at this and tell me if this will hold up to the power of the 440? You might have to click view discription to see the underside pics. Thank.
http://m.ebay.com/itm/Plymouth-Duster-Huge-no-reserve-on-select-cars-this-week-only-/331618011813?nav=SEARCH
I looked at the add and did not get the impression there was a big HP 440 under the hood. I would be more concerned about slicked over rust.
Looks very mild ? looks can be deceiving , it is definitely A BIG BLOCK.. a good set of frame connectors would be a good idea. Ties the front and rear frames together & stiffens the car..
With those tires no problem, they'll just spin. With traction lots of twisting.
Google search Dodge A Body Restoration and find some before pictures, they'll show the usual places to check.
Duster's never came with 440s , 340 or 360 or slant 6s . Someone could have put the 440 in it but if so you would think they would have also known to put frame connectors . The engine # is on the side of the block.
bsfor
08-22-2012 09:05 PM
